How to Read Football Odds for Beginners
To, co nie pasuje do innych działów czyli odzież, narzędzia, sklepy, warsztaty, prawo itd.
ODPOWIEDZ
macgaihari4
Post autor: macgaihari4 »
Understanding how to read football odds is essential for first-time sports bettors. Do you know how to read football odds yet? If not, let's take a look at the simplest guide on how to read football betting odds below. Our experts will guide you on how to read the most accurate odds.
Win big with our expert soccer tips vip
Reading Asian Handicap Odds in Football
Asian Handicap odds are the odds that bookmakers provide with a 1-goal handicap to the weaker team. Depending on the match, bookmakers will offer different handicaps, and here's how to read football odds for Asian Handicap:
0-0 Handicap
If you bet on the team that wins, you win.
If you bet on the team that loses, you lose.
If the match ends in a draw, your bet will be refunded regardless of the team you bet on.
1 Goal Handicap
With a 1-goal handicap, you'll see a handicap of 1 added to the weaker team. Here's how to read these football odds:
You choose the team with the handicap to win. If the stronger team wins by a margin of 2 goals or more compared to the weaker team.
If the stronger team wins by a single goal compared to the weaker team, you'll get a refund regardless of the team you bet on.
If the team with the handicap loses or the match ends in a draw, you lose your bet on the stronger team, and the weaker team wins.
¼ Goal Handicap
A ¼ Goal Handicap is represented with odds of 0.25 on the bookmaker's board. Here's how to read these football odds:
If the stronger team wins by a margin of 1 goal, you win your bet on the stronger team, and the weaker team loses.
If the stronger team draws or loses to the weaker team, you lose your bet on the stronger team, and the weaker team wins.
½ Goal Handicap
In this handicap, the stronger team gives a 0.5-goal handicap to the weaker team. Here's how to read a ½ goal handicap:
If the stronger team wins, you win your bet on the stronger team, and the weaker team loses.
If the stronger team loses or the match ends in a draw against the weaker team, you lose your bet on the stronger team, and the weaker team wins.
There are no cases in which the bookmaker refunds your bet on this handicap. Players who place bets will either win or lose. Therefore, consider your options carefully when choosing this type of bet.
¾ Goal Handicap
If the stronger team wins by a margin of 2 goals or more compared to the weaker team, you win your bet on the stronger team, and the weaker team loses.
If the stronger team wins by a single goal compared to the weaker team, you win half of your bet on the stronger team, and the weaker team wins half.
If the stronger team loses or the match ends in a draw against the weaker team, you lose your bet on the stronger team, and the weaker team wins the full amount.
Use betting tips app to win easily : what is asian handicap
How to Read European Football Odds
In European football betting, odds are represented on the bookmakers' boards as 1×2. Typically, bookmakers use this type of odds when the teams are evenly matched in terms of performance. When dealing with European football odds, you should follow the following reading method:
1: You bet on the home team -> If the home team wins, you win the bet.
2: You bet on the away team -> If the away team wins, you win the bet.
x: You bet on a draw result between the two teams -> If the match ends in a draw, you win the bet.
How to Read Over/Under Football Odds
Over/Under odds, also known as "Tài xỉu" in some regions, are a type of bet where the bookmakers don't require you to predict which team will win or lose. Instead, you need to predict the total number of goals scored by both teams compared to the bookmaker's set line. Here's how to read Over/Under football odds:
Over 0 goals
If there is at least one goal scored in the match -> You bet on Over, and you win.
If there are no goals scored in the match -> You bet on Under, and you win.
Over 1 goal
If the total goals scored by both teams are more than 1 -> You bet on Over, and you win.
If both teams fail to score a goal -> You bet on Under, and you win.
If the total goals scored by both teams are exactly 0 -> You get your stake back.
Over 1.25 goals
With Over 1.25 goals, you will encounter a specific Over/Under line when betting on football. Here's how to read this type of odds:
If the total goals scored by both teams are more than 2 -> You bet on Over, and you win.
If the total goals scored by both teams are exactly 1 -> You lose half of your bet on Over and win half on Under.
Over 1.5 goals
If the total goals scored by both teams are 1 or if there are no goals scored -> You bet on Under, and you win.
Tips for Analyzing Football Odds
To effectively analyze football odds based on the bookmakers' boards, consider these tips:
Master how to read football odds to make accurate betting choices.
Avoid chasing after bets with high payout odds, as they are often more challenging to win.
Analyze odds as soon as they are released by bookmakers to seize the best opportunities.
Compare odds from 2 to 3 reputable bookmakers to make informed betting decisions. This way, you can identify similar odds for placing your bets.
View more articles : betting tips in telegram
In general, understanding how to read football odds is not overly complicated, especially after reviewing our guide. If you found this article helpful, please consider sharing it on forums and with others to spread the knowledge.
ODPOWIEDZ
